Français
Expédition gratuite à partir de 55 $ !
Decription Caractéristiques Commentaires
NEW
ELEMNT MINI Bike Computer
89,99 €
Plus d’images
NEW
Simple cycling essentials to stay connected on your ride.
SKU# WFCC2
89,99 €
Commentaires
Description du produit
Wahoo ELEMNT MINI is the bike computer for those that want max data in a mini package! ELEMNT MINI comes with two connection options: phone free mode and phone mode. In both modes, the ELMENT MINI pairs seamlessly with the Wahoo RPM Speed Sensor included in the box, as well as other Wahoo heart rate monitors and cadence sensors. It works with our free ELEMNT Companion App that allows you to set up your data fields, customize profiles, track performance, and share ride data effortlessly - no more confusing menus! When in phone mode, the ELEMNT MINI gives you ride tracking, full ride data analysis, and call & text pop-up notifications. MINI is designed to work only with Wahoo dual-band sensors to ensure the connectivity – and in turn your ride experience – is absolutely flawless.
Caractéristiques
BOTH PHONE FREE AND PHONE MODE
Works with Wahoo dual-band sensors
The ELEMNT MINI is designed to work with the Wahoo TICKR heart rate monitors and Wahoo RPM speed & cadence sensors. It does not work with Wahoo sensors that are Bluetooth or ANT+ only.
Connexion et chargements sans fil
A truly wireless bike computer, meaning there's no need to tether up to your laptop to sync up ride data, download routes, or update the software. Everything can be uploaded via Bluetooth Smart to the ELEMNT Companion App.
Installation de l'appli associée
The free ELEMNT companion app allows you to set-up customized profiles, track performance, and share ride data effortlessly.
Écran entièrement personnalisable
Il y a une page pour chaque élément de votre parcours. Customize up to 5 pages of the workout data that matters most to you! Pas de menu ou de reprogrammation nécessaire.
Boutons intelligents
Two tactile and easy to press buttons on the bottom of the ELEMNT MINI allow you to quickly navigate to what you want to see and toggle between screens.
Partner App Automatic Uploads
Once sync'd with your favorite workout or cycling account, you are able send your data from ELEMNT MINI to your account with just one click via the free Companion App.
Speed Sensor Included
Wahoo dual-band speed sensor included so you can ride phone free with accurate speed, distance and time metrics.
1.8" Diagonal Screen Size
1.8" (45.7mm) diagonal display size that is larger than the leading competitor, so all your data is easy to see.
PHONE MODE ONLY*
Ride Tracking
When paired with your smartphone, record your ride via the smartphone's GPS so you have a full ride history of your route and ride statistics.
Live Track Portal
With Live Track, you can share a custom link with anyone via the ELEMNT Companion App so they are able to follow your ride in real-time on the Live Track web portal. Perfect for keeping you safely located by loved ones, tracked by a coach, or even meeting fellow riders in-route.
Text & Phone Alerts
Provides on-screen pop-up alerts to notify you when important contacts are trying to reach you. Available when you are riding with your smartphone.
*In Phone Mode, your smartphone must be with you on the ride and your ELEMNT MINI must be paired to the Companion App.
Click here for ELEMNT MINI instructions
Spécifications
Dimensions : 41x58.4x17mm OR 1.6x2.3x.67"
Taille d'affichage 1.8" (45.7mm)
Poids : 1.1 oz or 31 grams
Alimentation : Coin Cell
Durée des piles : ~1 Year
Notation de la résistance à l’eau : IPX7 (résistant à l’eau jusqu’à 1,52 m)
Résistant aux chocs : Oui
Wahoo RPM Speed sensor included
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 16.67ms
Caractéristiques
PHONE MODE ONLY*
Ride Tracking
Live Track Portal
Text & Phone Alerts
Spécifications
Commentaires
Powered By OneLink
