Support Aerobar/TT pour ordinateurs de vélo ELEMNT
14,99 €
Plus d’images
Rupture de stock
SKU# WFCC1M3
14,99 €
Commentaires
Description du produit
Notre support Aérobar/TT pour ordinateurs de vélo GPS ELEMNT de Wahoo est fait en matière plastique légère et durable ; il constitue, par ailleurs, le point d’observation idéal lors de votre triathlon ou de votre course contre la montre.
  • S’adapte à un poids complémentaire d’une aérobar de 22,2 mm
  • Poids : 8,5 g (0,3 oz)
  • Fonctionne avec l’ELEMNT, l’ELEMNT BOLT et l’ELEMNT MINI (Remarque : BOLT perd son avantage aérodynamique avec ce système de fixation).
  • Aerobar/TT Mount for ELEMNT Bike Computers is rated 3.0 out of 5 by 6.
    Rated 4 out of 5 by from Easy to mount A little hard to get really tight so I cut a small cube of rubber and put it in the mount, wow worked great. The issue is not all the TT bars are the same size, easy fix!
    Date published: 2017-10-22
    Rated 1 out of 5 by from Cheaply Made The mount is cheaply made and does not grab or lock well enough to keep the mount from moving on my TT bars. I tried to tighten it down and the lock bolt for the screw came right out of the plastic mount. After getting it back in, I re-tightened it just enough to stay on and then mounted it with black electrical tape. This needs to be improved so that you can get a more secure fit. I also tried added a thin piece of rubber to the mount ring to help make it lock snuggly, but the screw isn't long enough so tape was the best option.
    Date published: 2017-08-23
    Rated 2 out of 5 by from disappointed circumference to install around oa normal aero bar is too small. result is the super short screw isn't long enough to bring together the two sides of the circle. i have a normal aero bar and find the hours i have spent getting the screw to thread to the other side, or to find a longer screw at home depot ridiculous considering i paid $15 for a small piece of plastic. a longer screw would be great. right now i have an overpriced mount that is worthless because the tiny screw is too short.
    Date published: 2017-07-02
    Rated 4 out of 5 by from Nice little gem The mount does what you want to do it. No surprises, usual Wahoo quality. Why no 5*? Because there are 2 points of improvement in my opinion: 1) I think it should be 1-2 cm wider, it's now just a bit too tight towards the aerobar. My arm sometimes hits the ELEMNT Bolt while cycling. But, (un)tying the computer is no problem however. Maybe it's just my specific setup. 2) If you install it right out of the package, it will move once you touch it. So you need to put some tape on your aerobar, which solves this. I think Wahoo should included a little piece of rubber to prevent the motion. Overall, it works fine for me.
    Date published: 2017-06-22
    Rated 5 out of 5 by from Easy I bought it over a month ago and absolutely a must have.
    Date published: 2017-05-08
    Rated 2 out of 5 by from Wish it was industrial strength Product achieves my needs for an Aerobar mount but, unfortunately, the design of the bar attachment particularly the tightening screw is very weak.
    Date published: 2017-04-23
    • y_2018, m_1, d_18, h_5
    • bvseo_bulk, prod_bvrr, vn_bulk_2.0.6
    • cp_1, bvpage1
    • co_hasreviews, tv_0, tr_6
    • loc_en_US, sid_WFCC1M3, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
    • clientName_wahoofitness
    • bvseo_sdk, p_sdk, 3.2.0
    • CLOUD, getContent, 19.26ms
  • Caractéristiques
    Spécifications
    Commentaires
    Powered By OneLink
