Description Commentaires
Attache ELEMNT BOLT
14,99 €
Attache ELEMNT BOLT
Plus d’images
Attache ELEMNT BOLT
SKU# WFCCL1
14,99 €
Commentaires
Description du produit
Vous avez peur de perdre l’ordinateur de vélo le plus rapide sur le marché ? Notre attache spécifique à l’ELEMNT BOLT se visse à l’arrière de votre ELEMNT BOLT et permet à votre ordinateur de vélo de s’intégrer à son support avant en attente de brevet pour bénéficier de performances en matière d’aérodynamisme optimales.
  • Comprend une attache et une vis de fixation
ELEMNT BOLT Tether is rated 3.2 out of 5 by 19.
Rated 5 out of 5 by from A must have! Yes this product should be sold with the wahoo ELEMNT Bolt but it wasn’t so I spent extra cash and couldn’t be happier. It even works with the silicone protective cover that I bought for the Bolt.
Date published: 2018-06-29
Rated 3 out of 5 by from It's A Tether I agree with others; it's silly that this isn't included with Wahoo's units. The design seems pretty good, and it works. Minus 1 star for not being included, minus 1 star for not including the needed hex key for installation. Come on Wahoo, even Ikea includes the hex key with their furniture at the same price point!
Date published: 2018-06-19
Rated 5 out of 5 by from Looks Great I bought my tether a few months ago and it is great, it gives you some peace in mind knowing the Bolt will stay on your bars in the event of a crash. The tether also looks great on the Bolt when it is bolted on.
Date published: 2018-06-18
Rated 2 out of 5 by from Great idea, poor design In my opinion the tether is too long. Garmin overcomes this problem by making theirs stretchy which takes up the extra length. My main problem though is when I installed the screw into the Bolt, the soft plastic body threads stripped immediately making it useless. I have glued it on with silicone but I'm certain it will not hold if needed.
Date published: 2018-05-23
Rated 3 out of 5 by from Good safety device, why is it separate? I’m going to echo previous reviews saying why isn’t this included with the bolt already? Also the size of the bolt is rather odd, but a set of Wiha mini hexes are only $8 on prime and you have them for other applications after that, but then you are spending $18. Otherwise, this is a solid edition to your bolt, once I bought those Wiha’s I feel it’s tight enough on there to survive any fall it may have. Also the length of it is good for any winged bar you may have so you don’t have to worry. Great product, lost two stars, one for not coming with the bolt in the first place, and one for a bolt size not included in your standard cycling hex set, maybe that could at least be included in the packaging? Either way, buying this is cheaper than a new Bolt should it fall.
Date published: 2018-05-16
Rated 5 out of 5 by from Wahoo Bolt tether I bought it to make sure that I wouldn’t loose my wahoo Bolt and it worked all ready
Date published: 2018-04-24
Rated 1 out of 5 by from Over Engineered, Overpriced, and sadly necessary The design of this thing is way too complex for what it is. It should be in the box with the unit, and it should not cost $10 for a piece of string and a screw.
Date published: 2018-04-14
Rated 1 out of 5 by from Tether I would have thought that this tether would've been included in the purchase of the Bolt. When I installed it and tried to tighten it down, it stripped the thread (being a cyclist, I don't have a lot of upper body strength so I didn't put a lot of torque on it). Also, with the Garmin tether, it came with a clip so that the string is short and I don't have to wind it around my handlebars to take up the extra string.
Date published: 2018-03-10
  • y_2018, m_7, d_17, h_6
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_19
  • loc_en_US, sid_WFCCL1, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 29.25ms
Caractéristiques
Spécifications
Commentaires
Powered By OneLink
