Support potence pour ordinateurs de vélo ELEMNT
14,99 €
Plus d’images
Rupture de stock
SKU# WFCC1M2
14,99 €
Commentaires
Description du produit
Notre support potence pour les ordinateurs de vélo GPS ELEMNT de Wahoo est fait en matière plastique légère et durable ; il est en outre une solution parfaite pour les cyclistes qui préfèrent garder leur ordinateur en haut de la potence.
  • S’adapte à n’importe quelle potence
  • Poids : 5,6 g (0,2 onces)
  • Fonctionne avec l’ELEMNT, l’ELEMNT BOLT et l’ELEMNT MINI (Remarque : BOLT perd son avantage aérodynamique avec ce système de fixation).
  • Comprend quatre (4) attaches autobloquantes pour la fixation
Stem Mount for ELEMNT Bike Computers is rated 2.8 out of 5 by 16.
Rated 2 out of 5 by from Needs work Doesn't "fit any stem" as advertised. My Canyon CX and MTB both have a square, not round, stem, so it doesn't fit without taking off the rubber which then makes it less secure. I had to move it over to the handlebars. Who uses zip ties anymore? You can never get them tight enough.
Date published: 2018-05-17
Rated 1 out of 5 by from Zip Ties = Thumbs Down Agree with other reviews. The zip tie attachment is awful. Garmin rubber band design is way better! Also, should be m more that $6.
Date published: 2018-05-06
Rated 2 out of 5 by from Way overpriced Works really well, I use it on my second bike. However, the price is so, so high, especially with postage. Sort it out, Wahoo!
Date published: 2018-05-01
Rated 3 out of 5 by from Works but there are better designs It does the job but it's expensive for small piece of plastic. I also semi-regularly swap between different bikes so the cable ties are a pain. For all their faults, the Garmin version with the rubber bands is a much better solution.
Date published: 2018-01-09
Rated 2 out of 5 by from Zipp Tie Its functional but the zip ties are a pain. Would prefer a rbber band solution.
Date published: 2018-01-04
Rated 3 out of 5 by from Good,needs 1 thing. This needs an additional piece of rubber stripping to place under the stem.As sold,with the nylon ties alone,the Wahoo rotates too easily,no matter how tight the ties are.
Date published: 2017-11-13
Rated 1 out of 5 by from Not good Look at the garmin solution, look at this solution.....its garbage. Trim 2-3mm of one side of your garmin mount to make the slot wider, then your wahoo will fit in it. Meanwhile, wahoo designers,
Date published: 2017-09-15
Rated 3 out of 5 by from Works fine but way too expensive $15 for this little mount...come on. Consider this additional expense if pondering the switch from a Garmin.
Date published: 2017-07-14
  • y_2018, m_6, d_20, h_19
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_14
  • loc_en_US, sid_WFCC1M2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 132.98ms
Caractéristiques
Spécifications
Commentaires
Powered By OneLink
