Support avant extérieur pour ordinateurs de vélo ELEMNT
19,99 €
Plus d’images
Rupture de stock
SKU# WFCC1M1
19,99 €
Commentaires
Description du produit
Le support avant pour ordinateurs de vélo GPS ELEMNT de Wahoo est fait en matière plastique légère et durable ; il est parfait car il permet de concentrer votre regard sur les données et sur la route.
  • S’adapte au guidon rond de 31,8 mm :
  • Poids : 19,8 g (0,7 oz)
  • Fonctionne avec l’ELEMNT, l’ELEMNT BOLT et l’ELEMNT MINI (Remarque : BOLT peut perdre son avantage aérodynamique avec ce système de fixation).
Out Front Mount for ELEMNT Bike Computers is rated 4.1 out of 5 by 14.
Rated 4 out of 5 by from Exactly what I needed I looked at a few mounts and I went with the Wahoo Out Front Mount because of it’s clean look.Some of the others Quality construction and sturdy.
Date published: 2018-02-18
Rated 4 out of 5 by from Good product - but expensive It's a bracket - it's well-engineered and good quality; but almost $50? Seems darned expensive for what it is.
Date published: 2018-01-25
Rated 5 out of 5 by from It's a mount! It's hard to write a review on something that is simple and does what it should. I will say this, other brands of the same size computer want you to use a little tether cord in case it comes loose. That notion alarms me. The elemnt mount is rock solid. Through a lot of road and harsh gravel riding it has never so much as twitched loose. It works like it should. I always feel confident it will keep the computer safe.
Date published: 2018-01-19
Rated 4 out of 5 by from Pretty much exactly what it says it is It's an extra out in front mount, same as the the kind that comes stock on the regular elemnt, no surprises, made of plastic, rubber grip for the bar wish it was either one penny more expensive so it would qualify for free shipping or five bucks cheaper, because 20 plus shipping seems a bit much for what it is, mounts solid, hinge is kind of annoying for the positioning of it, but easy enough to get in place
Date published: 2017-11-28
Rated 1 out of 5 by from Nice but...loses the computer too easily. It is much too easy to lose your expensive device! The resistance to rotate the computer needs to be increased. The mount comes with a screw to permanently lock the device however this is not realistic or easy to use if you want to remove the computer for charging, or using on another bike. The majority of friends who have these have lost their device. :(
Date published: 2017-10-17
Rated 4 out of 5 by from can be better i bought 2 additional front mounts for my other bikes. It would be great if it comes with some additional rubber shim that would help to clamp on some smaller size handlebars.
Date published: 2017-08-28
Rated 4 out of 5 by from Secure, great location, but only fits 31.8mm bars I got a 2nd mount to put on my other bike, an old touring bike with 25.4mm bars. This is designed for 31.8mm and doesn't come with an adapter, so I had to hunt around for some thick rubber pads to fill the gap. Otherwise a great way to mount the Elemnt.
Date published: 2017-08-22
Rated 5 out of 5 by from Sturdy mount Pleased with this mount. It holds my Elemnt securely and there's no vibration. In my opinion having the Elemnt a few inches ahead of the bars gives a more comfortable view than a stem mount
Date published: 2017-08-04
  • y_2018, m_4, d_20, h_10
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_13
  • loc_en_US, sid_WFCC1M1, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 16.87ms
Caractéristiques
Spécifications
Commentaires
Powered By OneLink
