Description Commentaires
Adaptateur d’axe traversant KICKR SNAP 12x142
79,99 €
Plus d’images
Pour toutes les versions du Wahoo KICKR SNAP
SKU# WFSNAP142
79,99 €
Commentaires
Description du produit
Notre kit axe traversant contient tout ce dont vous avez besoin pour monter la plupart des vélos avec axe traversant 12x142 sur votre home trainer d’intérieur KICKR SNAP. Cet accessoire fonctionnera avec toutes les versions du Wahoo KICKR SNAP. Il comprend les éléments suivants :
  • Entretoise d’axe enfilé M12 x 1,75 Gros
  • M12 x 1,5 moyen
  • M12 x 1,0 fin
  • Capuchon
Remarque : ce kit est compatible avec les vélos 12x142 uniquement. Ne fonctionne pas sur les modèles 12x135, 12x148, ou sur aucun autre système avec axe traversant. Veuillez regarder la vidéo d’installation de l’adaptateur SNAP avant d’essayer de l’installer par vous-même. Si vous avez des questions, n’hésitez pas à nous contacter !
KICKR SNAP 12x142 Thru Axle Adapter is rated 3.6 out of 5 by 14.
Rated 3 out of 5 by from Solid product I am a big fan of Wahoo products but am annoyed I had to buy 3 piece set at triple the cost when only one size is needed. I understand that different bikes take different adapters but it shouldn’t be that hard to identify the one size needed so as to avoid payment for three.
Date published: 2017-12-28
Rated 3 out of 5 by from Axle works fine, way over priced! I bought this about a month ago. I needed it in order to use my new SNAP. Unfortunately I was unable to find a reasonably priced substitute. For whatever reason these trainer axles are ridiculously expensive. I only needed one. Why can't Wahoo sell them individually? Or at least price them more reasonably. It works fine with the trainer and my bike. Not sure what to do with the other two. Maybe I'll used them as door stops or something.
Date published: 2017-11-28
Rated 3 out of 5 by from It works-expensive I had to order these to go with my SNAP as the one it came with was much too skinny. Glad I was able to make it work, but $80 is absurd. They should also sell these in singles. I have two axles now I’ll not need.
Date published: 2017-11-02
Rated 1 out of 5 by from Overpriced! Overpriced for a piece that should come with the 2017 Kickr Snap. I still had to go to Home Depot to but washers to keep everything tight. Waste of money and a waste of time.i waited a week to receive this.
Rated 3 out of 5 by from Expensive and a bit clunky $80 for a trainer axle is nuts. Now, you get 3 when you plop down that money, but you're generally only going to need 1. Also, having to swap out the trainer cup if you put a QR axle bike on it clunky. Take a look at The Robert Axle Project. They're a good bit cheaper and don't require a cup change. Lastly, if you're also looking at the Kinetic axle, keep in mind you'll need a 18mm socket/wrench to remove it, so you'll need to swap in your original axle every time you go from the trainer to the road. Ugf.
Date published: 2017-04-04
Rated 1 out of 5 by from Stupid expensive Product works just fine but it's riduclous that you need to buy 3 for $75 when you only need 1. Please start selling them individually.
Date published: 2017-02-23
Rated 4 out of 5 by from 1/3 good works fine ... dont like having to pay for 3 when i use only one
Date published: 2017-02-05
Rated 5 out of 5 by from Let me ride my thru-axle bike on the SNAP! I recently purchased a Cervelo R3 with disc brakes, which has a through axle and therefore doesn't fit the SNAP. After trying two other adapters. This one fit and works and I was able to donate my old bike to a good cause.
Date published: 2016-08-01
  • y_2018, m_1, d_19, h_16
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.6
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_13
  • loc_en_US, sid_WFSNAP142, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 15.13ms
  • M12 x 1,5 moyen
  • M12 x 1,0 fin
  • Capuchon
Caractéristiques
Spécifications
Commentaires
Powered By OneLink
