Description Commentaires
Broche de blocage et adaptateur de moyeu KICKR
19,99 €
Plus d’images
Pour toutes les versions du Wahoo KICKR
SKU# WFSKEWERHUB
19,99 €
Commentaires
Description du produit
Cet ensemble de pièces comprend une broche de trainer à démontage rapide en acier et un adaptateur de moyeu de 130/135mm. La broche est compatible avec toutes les versions du home trainer d’intérieur Wahoo KICKR et mesure 165 mm.
KICKR Skewer and Hub Adapter is rated 4.1 out of 5 by 10.
Rated 5 out of 5 by from Replacement part I inherited a wahoo kickr and when I got home I noticed I was missing a piece. I called my bike shop, asked around and did some searching on the web and couldn't find anything. One guy found a piece for me but we realized that was for disc brake bike... I contacted wahoo service and in no time they responded, I sent pics of my trainer and the guy told me exactly which piece to get (he attached a link) The piece is perfect and the service is unbeatable
Date published: 2018-10-03
Rated 5 out of 5 by from Exactly what I needed Had to buy a replacment since the last one got "lost" in a move. What can I say other than it's a needed part for the Kickr.
Date published: 2018-05-01
Rated 3 out of 5 by from Skewer works I bought this to replace a trainer skewer with a quick release that no longer tightened. This skewer tightens, so it accomplishes what I needed. However, it came with no instructions on how to use the adapter, or exactly what the adapter is for. I was hoping that it would slot in between the skewer and KICKR, because my KICKR’s metal cylinder (the part that holds the skewer in place) is completely extended and won’t extend any more. But after spending 45 minutes trying to put this adapter in every configuration I could figure out, it doesn’t appear to help.
Date published: 2018-04-05
Rated 5 out of 5 by from Worked great! Wonderful and easy to install and change for various bikes and axel set ups!
Date published: 2017-11-29
Rated 5 out of 5 by from Works like a charm I own a non through axle road bike. I purchased my daughter a specialized ruby and didnt pay attention to the different axle and of course my daughter wanted to use MY kickr ( lol ) . I purchased this adapter ( putting it on was a piece of cake ) and now she's in business !
Date published: 2017-08-11
Rated 5 out of 5 by from 12 x 142 Adaptor is Perfect Great product, easy to set up. However this should be a standard item included with the Wahoo Kickr purchase. Many bikes now a days use 12 x 142 setup, Wahoo needs to recognize this and make the appropriate adjustments with no or extremely minimal price change.
Date published: 2017-02-01
Rated 2 out of 5 by from Functional, but not what came on the Kickr origina This is just a plain old cheapo skewer. It does not have nearly the leverage or fit of the original which could wrap around the dropouts and fully close in a traditional 45 degree angle. Should have just gotten any old skewer, I thought the original had extra length for a reason (on the handle).
Date published: 2017-01-31
Rated 5 out of 5 by from Well made. Works with Snap. We recently purchased a Kickr Snap, and we have three bikes in the family that all get use on the Snap. Ordered two skewers/hub adapters in addition to the one that came with the Snap. They are all the same; all work very well. Definitely nice to have adapters that fit the Snap perfectly and don't risk damage to the bike's original skewer nor frame.
Date published: 2016-02-02
  • y_2018, m_10, d_21, h_1
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_8
  • loc_en_US, sid_WFSKEWERHUB, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 18.33ms
Caractéristiques
Spécifications
Commentaires
AVERTISSEMENT : Cancer and Reproductive Harm - www.P65Warnings.ca.gov
Powered By OneLink
