Corps de cassette Shimano
59,99 €
Plus d’images
For the 2014 Edition and 2016 Edition KICKR
Rupture de stock
SKU# 000-0396
59,99 €
Commentaires
Description du produit
Ce moyeu rend votre home trainer KICKR compatible avec les cassettes de vitesse Campagnolo 9, 10 et 11. Il fonctionnera uniquement avec les versions 2014 et 2016 du KICKR.
Remarque : l’installation est requise ! Veuillez consulter notre site d’assistance pour obtenir les instructions de l'Adaptateur Shimano. La Cassette Shimano et l’anneau de verrouillage ne sont pas inclus. Veuillez vous assurer d’avoir tous les outils nécessaires avant l’achat. Si vous ne souhaitez pas effectuer l’installation vous-même, le magasin de vélo proche de chez vous aura les outils et le savoir-faire nécessaires pour vous permettre de vous remettre en selle !
Shimano Freehub for KICKR Smart Trainer is rated 3.8 out of 5 by 4.
Rated 5 out of 5 by from Fixed my freewheeling issue My kickr wouldn’t freewheel, it ended up being the freehub body wearing away. Luckily the axle it mounts to is undamaged and it works perfectly with the new spacer and freehub
Date published: 2018-03-13
Rated 5 out of 5 by from Perfect! On time, easy install, great support! After thousands of miles in my kickr, this was a much needed replacement of a component that is expected to wear over time. Replacing greatly improved ride fee and fluidity on my kickr.
Date published: 2018-02-05
Rated 1 out of 5 by from Not necessary I bought this item (at the same time as buying my KICKR smart trainer) as a result of reading a previous purchasers review that said you need to change the supplied hub if you have a 10 speed shimano gear set on your donor bike. On closer inspection the original/supplied hub is Shimano esk and all I needed was a spacer so I returned the hub.
Date published: 2017-11-17
Rated 4 out of 5 by from Few mishaps but good service in the end. After some misunderstandings between costumer service and I we found a good solution. Glad I got the freehub it's nice my Kickr works again.
Date published: 2017-04-13
  • y_2018, m_12, d_13, h_18
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_000-0396, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 15.03ms
Caractéristiques
Spécifications
Résidents de la Californie :  Voir notre Offre Spéciale 65 AVERTISSEMENT
Commentaires
AVERTISSEMENT :Cancer et effets nocifs sur la reproduction -www.P65Warnings.ca.gov
Powered By OneLink
