ELEMNT RIVAL
RUNNING WATCH
ELEMNT RIVAL creates a seamless training and racing experience for runners. Powered by proven ELEMNT technology to provide a simple user experience to set up and customize the device to fit your lifestyle. With optical heart rate, barometric altimeter, ceramic bezel and water resistance up to 50m, ELEMNT RIVAL is your next GPS watch for running.
ACHETER MAINTENANTJim Walmsley - Western States 100 Champion
TOUJOURS. RESTER. CONCENTRÉ.
ELEMNT RIVAL uses the intuitive ELEMNT OS to make the setup, customization and user experience of this GPS sport watch simple and seamless. Featuring a durable ceramic bezel, RIVAL boasts accurate GPS to track and record your runs, whether on the track, road or trails.
SIMPLICITÉ DU SUIVI
With powerful and intelligent running features, ELEMNT RIVAL tracks time and workout data with minimal interaction between you and your watch, letting you concentrate on the task at hand – your training and race-day performance.
ACHETER MAINTENANT
FRÉQUENCE CARDIAQUE OPTIQUE
Check your heart rate and calorie data at a glance with ELEMNT RIVAL's built in optical heart rate. Set your zones in the ELEMNT Companion App to keep a pulse on your efforts.
ENTRAÎNEMENTS PLANIFIÉS
Sync your TrainingPeaks calendar or choose one of our pre-loaded Wahoo Sports Science workouts to execute on RIVAL. As you run, interval prompts and target tracking are built into your sessions to keep you on pace.
FONCTION TRACK RUNNING
Use RIVAL's tracking running feature to snap to the nearest 100m distance on any standard 400m track to ensure your workout data is as accurate as possible.
MINUTEUR DE REPOS/ENTRAÎNEMENT
Build out the intervals to fit your training. Create set periods for work and rest time and get prompted notifications during your workout to stay on track.
Simple à voir
Avec un grand écran couleur qui utilise un capteur de lumière ambiante et la technologie Perfect View Zoom™, l’ELEMNT RIVAL fonctionne dans toutes les conditions de luminosité afin de pouvoir consulter vos données d’entraînement les plus importantes en un coup d’œil.
ACHETER MAINTENANT
CAPTEUR DE LUMINOSITÉ AMBIANTE
Le capteur de lumière ambiante de l’ELEMNT RIVAL maintient vos données d’entraînement visuellement accessibles même lorsque les conditions sont loin d’être idéales.
CIBLER
VOTRE OBJECTIF
Grâce à Perfect View Zoom™, la montre connectée ELEMNT RIVAL vous permet d’effectuer un zoom avant et arrière sur des données d’activité physique spécifiques afin que vous puissiez facilement voir les mesures qui comptent le plus pour vous.
CRISTALLIN
L’ELEMNT RIVAL est construite à l’aide du verre Gorilla Glass, offrant un écran très fiable et résistant aux impacts, qui garantit à votre montre d’être aussi solide que votre régime d’entraînement.
OPTIONS COLORÉES
La résolution 240 x 240 de l’ELEMNT RIVAL fournit des données de performance avec un affichage LCD 64 couleurs personnalisable et facile à voir, que ce soit dans la piscine ou pendant la course.
Facile à utiliser
With the most intuitive user interface, ELEMNT devices have dramatically changed the way athletes interact with their devices. ELEMNT RIVAL is optimized to give runners a focused advantage.
ACHETER MAINTENANTL’EXPÉRIENCE ELEMNT
L’appli gratuite associée ELEMNT offre une interface de smartphone facile à utiliser qui vous guide dans la configuration, la création d’un profil d’entraînement, la personnalisation d’écrans d’entraînement et la liaison entre votre ELEMNT RIVAL et vos applications de fitness préférées et capteurs sans fil.
NOTIFICATIONS INTELLIGENTES
Avec l’ELEMNT RIVAL, localisez facilement vos amis en temps réel pendant leurs entraînements. Et recevez également des e-mails, des SMS et des notifications afin de toujours rester en contact, même lorsque vous n’êtes pas joignable.
PLUS CONNECTÉS
Que vous aimiez pédaler, courir, nager ou simplement pratiquer une activité physique, l’ELEMNT RIVAL peut être reliée aux appli d’entraînement et aux capteurs sans fil les plus populaires pour offrir une expérience d’entraînement complète.
SYNCHRONISATION SANS FIL
L’ELEMNT RIVAL offre une expérience de liberté totale : plus besoin de perdre de temps à chercher les câbles de connexion pour ordinateur portable afin de synchroniser les données d’entraînement ou de mettre à jour le logiciel de votre montre.
APPLICATION AVEC TUTORIEL
Découvrez l’ELEMNT RIVAL en toute simplicité grâce à sa suite de tutoriels étape par étape. Les instructions faciles à suivre vous guident à travers les caractéristiques uniques de la RIVAL, vous garantissant ainsi de profiter pleinement de votre montre.
ÉDITEUR D’ENTRAÎNEMENT
Use Workout Editor on the ELEMNT Companion App to correct your segment timing on the Track Running or Triathlon profiles for variations between your watch and the official race results.
CONTRÔLE KICKR
L’ELEMNT RIVAL vous permet d’effectuer votre entraînement de vélo en intérieur. En vous connectant aux Home Trainers intelligents KICKR de Wahoo, vous avez le contrôle total du Home Trainer intelligent approuvé par Jan Frodeno, médaillé d’or olympique et triple champion du monde IRONMAN.
CARACTÉRISTIQUES TECHNIQUES
CARACTÉRISTIQUES | |
Dimensions | 46,5 x 46,5 x 15,3 mm |
Taille d’affichage | Diamètre de 1,2 po (30,4 mm) |
Type d’affichage | Couleur |
Résolution de l’écran | 240 x 240 |
Matériau du verre | Gorilla® Glass |
Matériau de la lunette | Céramique |
Matériau de l’étui | Polymère nylon |
Matériau du bracelet | Silicone |
Longueur de la sangle | 10 po (25,4 cm) S’adapte à la circonférence du poignet 140 mm - 240 mm |
Poids | 53 g |
Alimentation | Lithium-ion rechargeable |
Durée de vie des piles | Mode montre connectée : 14 jours GPS ou mode HR (rythme cardiaque) : Jusqu’à 24 heures |
Fonctionnalité GPS | Intégrée |
Satellites pris en charge | GPS et GLONASS |
Notation hydrique | 5 ATM (étanche jusqu’à 50 mètres) |
Boutons de zoom Perfect View | Oui |
Capteur de luminosité ambiante | Oui |
CONNECTIVITÉ | |
Connectivité sans fil | ANT+® et Bluetooth® |
Compatibilité du capteur | ANT+®, BLUETOOTH® et FE-C ANT+ |
Compatibilité avec les téléphones | iPhone et Android |
CAPTEURS | |
Altimètre | Oui |
Boussole | Oui, à partir du GPS |
Gyroscope | Non |
Accéléromètre | Oui |
Thermomètre | Non |
CARACTÉRISTIQUES DE L’HORLOGE | |
Heure/Date | Oui |
Synchronisation du temps GPS | Avec l’appli compagnon ELEMNT |
Heure d’été automatique | Avec l’appli compagnon ELEMNT |
Minuterie | Oui |
Chronomètre | Oui |
FONCTIONNALITÉS INTELLIGENTES | |
Installation de l’appli compagnon | Oui |
Écran personnalisable | Oui |
Notifications | Appel, SMS, e-mail, WhatsApp, Signal, Line, Telegram et WeChat |
Suivi en direct | Avec l’appli compagnon ELEMNT |
Contrôle la musique des smartphones | Oui (iOS uniquement) |
Téléchargement automatique des entraînements | Oui |
FONCTIONS DE SUIVI DES ACTIVITÉS | |
Compteur de pas | Oui |
Calories brûlées | Oui, calories actives |
Étages montés | Non |
Distance parcourue | Oui |
Minutes d’activité intense | Non |
Temps d’activité physique | Oui |
Distance hebdomadaire natation/vélo/course | Oui |
Profils d’activité | Vélo d’intérieur (KICKR), vélo d’extérieur, course en extérieur, tapis roulant, course sur piste, longueurs (piscine), natation en eaux libres, exercices de force, yoga |
FONCTIONS D’ANALYSE D’ENTRAÎNEMENT | |
Zones HR | Oui |
Calories HR | Oui |
Mesures de diffusion Bluetooth et ANT+ | Rythme cardiaque, allure de course et cadence de course |
Vitesse et distance GPS | Oui |
Pages de données personnalisables | Oui |
Profils d’activité personnalisables | Oui |
Pause automatique | Oui |
Auto Lap | Oui |
Enregistrement manuel des tours | Oui |
Invites audio | Oui |
Heure de fin | Oui |
Activités multisports automobiles | Oui |
Activités multisports manuelles | Oui |
Verrouillage de bouton | Oui |
Historique des activités sur la montre | Oui |
INTÉGRATIONS | |
Applications d’activité | Strava, TrainingPeaks |
Home trainers d’intérieur | Home trainers intelligents Wahoo et home trainers dotés de la technologie ANT+ FE-C |
RESSOURCES DE L’ELEMNT RIVAL
Consultez ces ressources pour apprendre comment profiter au maximum de votre ELEMNT RIVAL et de votre expérience d’entraînement !
What does proper running form look like? That depends on the individual, but there are principals to understand and aim for to ensure proper individual form. Learn what that means and how to apply it to your own training.
Do These Drills, Run Faster
How do you run faster? You may think, run more...but that is not always the answer and often leads to increased injury incident. Check out tips from our experts as to how to get faster in a safe and strategic way.
Ask the Experts: Tips for Running Through Tough Terrain
Branching out to more technical terrain often involves climbing, descending, and managing your footing, and is a much different experience than the path runs you’ve been knocking out. Learn more about how the type of terrain plays into your training, your level of fitness, and overall approach.
MA RAISON | #MyRIVAL
Chacun d’entre nous a un rival qui nous pousse à nous dépasser. Découvrez celui des athlètes Wahoo.
PARTAGEZ VOTRE RIVALDEVENEZ UN WAHOOLIGAN
L’étiquette #MyRIVAL ou @wahoofitnessofficial doit être présente. Les conditions générales s’appliquent.
