One Bike Computer. Your Central Cockpit.
You’ve spent a lot of time building your bike and planning out the perfect ride. You’ve got your fit dialled in just right, sensors and lights added on your frame, and the apps that know your training history inside out. The last thing you need is a new bike computer that asks you to start from scratch.
The ELEMNT GPS bike computer is designed around a simple principle: it should work with what you already have, and expand with what you want next. Whether that’s a new radar sensor or your preferred training platform, ELEMNT is built to connect and let you just ride.
This is your complete ELEMNT compatibility guide of what works with what, and how to get the most out of every integration available.
“Which sensors are compatible with ELEMNT bike computers?”
The ELEMNT bike computer range supports the full array of sensors you would expect, and several you might not.
ELEMNT GPS bike computers connect to sensors via both ANT+ and Bluetooth Low Energy protocols, giving you broad compatibility across brands and sensor types. Here is a breakdown of what connects and how.
Speed, Cadence, and Power
ELEMNT connects to all standard ANT+ and Bluetooth speed sensors, cadence sensors, and power meters, regardless of brand. If your sensor transmits on ANT+ or Bluetooth, your ELEMNT will find it.
This includes power meters from Stages, Garmin, Favero, Quarq, Shimano, SRM, and others. Dual-sided, single-sided, pedal-based, crank-based. The protocol matters more than the brand, and ELEMNT speaks to them all to display standard fields like power and left/right balance on your bike computer.
Fréquence cardiaque
ELEMNT pairs with all ANT+ and Bluetooth heart rate monitors, including the Wahoo TRACKR and TICKR FIT. Chest strap, optical armband, or wrist/watch based. If it broadcasts heart rate data over ANT+ or Bluetooth, your ELEMNT can read it.
Electronic Drivetrains and Shifting
ELEMNT ACE, BOLT 3, and ROAM 3 all support integration with electronic shifting systems, including Shimano Di2, SRAM eTap AXS, and Campagnolo EPS.
What does this give you in practice? Gear data displayed live on your bike computer screen, including current gear, front and rear position, and in some configurations, drivetrain battery level. For riders who want the complete picture of what their drivetrain is doing at any given moment, this integration delivers it without any additional hardware. Full details are available in the electronic drivetrain support guide.
Radar Sensors
ELEMNT integrates with ANT+ radar sensors, including the Wahoo TRACKR RADAR and Garmin Varia. When a compatible radar sensor detects a vehicle approaching from behind, a visual alert appears directly on your ELEMNT GPS display, so you do not need to glance at a separate device or take your attention off the road.
The Wahoo TRACKR RADAR operates on the open ANT+ Radar standard; it is not limited to Wahoo GPS devices. It is designed to work with any ANT+ compatible bike computer, including those from other brands. Find out more here about using TRACKR RADAR with third party devices or how to use with a third generation ELEMNT bike computer here
NOUVEAUTÉ ! Sweat Hydration Sensors
Traditional sensors tell you how hard you are working. A new category of sensor integrations with ELEMNT now tell you what your body is losing in the process.
ELEMNT BOLT 3, ROAM 3 and ACE now integrate with Flowbio and hDrop to track sweat loss and sodium loss in real time, directly on the device. Two metrics that have historically required lab testing or post-ride analysis are now available as live data fields during your ride.
- Cumulative Fluid Loss measures the total volume of sweat lost during a ride in liters, giving you a real-time view of fluid depletion as it happens rather than a retrospective estimate after the fact.
- Cumulative Sodium Loss measures the total sodium lost through sweat in milligrams, helping you understand your individual electrolyte depletion rate and make informed decisions about supplementation during and after training.
Together, these metrics answer questions that power and heart rate data simply cannot: How much fluid have I actually lost? What is my sodium depletion rate? Am I replacing what my body needs?
Integration is native and plug-and-play. There is no app store installation and no manual session starts required. The sensor begins logging automatically when your ride begins, and the data fields sit alongside power, heart rate, and cadence in your configurable display layout.
By bringing biomarker-grade sweat analytics onto the ELEMNT bike computer experience, Wahoo makes precision hydration management actionable in real time, not something athletes analyse only after the effort ends.
NOUVEAUTÉ ! Breathing Sensors
Breathing has always been a signal, now makes it a measurable one with the Tymewear VitalPro Integration .
This respiratory sensor integration delivers three ventilation-based metrics live on the device, adding a layer of physiological insight that power and heart rate alone cannot provide.
- Minute Ventilation (VE) measures the total volume of air moved per minute and is the most direct indicator of respiratory load. VE rises predictably through aerobic thresholds, making it a reliable guide for zone-based training and a useful early signal that intensity is climbing beyond a sustainable level.
- Breathing Rate (BR) tracks breaths per minute, allowing you to monitor breathing rhythm during efforts and identify when intensity is pushing into unsustainable territory before other metrics catch up.
- Tidal Volume (Vt) measures the air moved per individual breath, giving you a window into breathing efficiency and how deeply you are working at different intensities.
Beyond individual metrics, ELEMNT supports ventilation-based training zones configured around scientifically validated thresholds, including Endurance, VT1 (aerobic threshold), VT2 (anaerobic threshold), Top of Zone 4, and VO2max. Your current ventilation zone is displayed in real time with colour-coded backgrounds and time-in-zone tracking throughout the ride, exactly as you would expect from power or heart rate zones.
These metrics answer the questions that effort-based data cannot: Am I breathing efficiently? Have I crossed my aerobic threshold? Can I sustain this pace?
Heat and Thermal Stress Sensors
Heat is one of the most significant performance variables in endurance sport and one of the least well understood in real time. Raw body temperature numbers do not always answer the questions that matter most during a ride: Is this level of heat actually affecting my performance? Am I approaching a level of strain that warrants backing off?
ELEMNT’s expanded CORE body temperature integration addresses this by translating thermal data into two intuitive metrics.
- Heat Zone provides a colour-coded view of an athlete’s current thermal state, ranging from cool and low strain through to high heat stress. Like heart rate or power zones, Heat Zone allows you to assess heat impact at a glance without needing to interpret raw temperature values in the moment.
- Heat Strain Index (HSI) is a composite metric that reflects overall physiological heat stress, combining trends in core body temperature and skin temperature into a single number that reflects cumulative thermal load. HSI is particularly useful during long rides, races, or training blocks in hot environments where heat accumulates gradually and the effects build over time.
On the device, both metrics are displayed in real time with clear colour mapping aligned to CORE’s official heat indicators. No phone connection is required during the ride.
By integrating heat metrics alongside familiar performance data, Wahoo makes thermal stress a first-class training signal, instead of an afterthought.
“Which training and routing apps connect directly to ELEMNT?”
A wide range of third party apps work directly with Wahoo ELEMNT bike computers. Here is a growing list of verified app partners that sync directly through the Wahoo ecosystem.
Apps That Push Planned Workouts to ELEMNT
These platforms connect to your Wahoo app account and can automatically push structured workouts to your device, ready to follow on your next ride:
- Wahoo App & SYSTM
- TrainingPeaks
- intervals.icu
Apps That Sync Routes to ELEMNT
These platforms connect to push planned and newly created routes directly to your device before you ride:
- Komoot
- RideWithGPS
- Strava
- Bikemap
- MapMyFitness
- Trailforks
Apps That Receive Completed Ride Data from ELEMNT
Once you finish a ride and sync your ELEMNT, these platforms receive your activity automatically when authorized in the Wahoo App:
- Strava
- TrainingPeaks
- Apple Health
- Xert
- Intervals.icu
- Runalyze,
The full and current list of authorised app partners is maintained in the Wahoo App Partners directory, and the process for connecting a new app is covered in the app authorization guide.
The Bigger Picture: Compatibility as a Design Principle
It would be easy to treat compatibility as a checklist of supported devices and leave it there. But the reason ELEMNT bike computers work with such a broad range of sensors, apps, and platforms is not incidental. It reflects a deliberate decision to build around open standards rather than proprietary ones.
ANT+ and Bluetooth are industry-wide standards that allow any compliant device to communicate with any other compliant device, regardless of brand. When Wahoo builds the ELEMNT experience around these standards, the practical effect is that your existing investment in sensors, software platforms, and hardware is protected. You are not starting over, but adding to what you already have.
The same principle extends to the newer sensor categories. Hydration sensors, respiratory sensors, and thermal sensors all integrate natively into ELEMNT’s configurable data fields without proprietary workarounds or third-party app dependencies. As the range of sensors available to cyclists expands, the ELEMNT is built to grow with it.
What It Comes Down To
The ELEMNT GPS cycling computers are designed to be the center of your cycling setup, not a replacement for it. Sensors connect regardless of brand. Training and routing apps sync automatically in both directions. New categories of physiological data, from sweat analytics to respiratory metrics to thermal strain, are integrated natively and displayed where you actually need them: on the device, during the ride.
Compatibility is not an afterthought in the ELEMNT experience, it is built to ensure seamless connectivity so you have everything at your fingertips before, during, and after each ride. Explore the ELEMNT GPS range and find which GPS cycling computer is best for your unique goals and riding style.
